The cross section is a rectangle. Its height is associated with a variable H.
I created a table htab1, the shape of it is like this
I created 2 segments:
Segment1 use link segment, and its vartiable H was associated with htab1;
Segment2 use regular segment, and its vartiable H was associated with htab1 too.
The resulting model of Segment1 has steped shape, which is wrong
while the resulting model of Segment2 has smoothed shape, which is correct
The TCL is attached: 4863.gp9.zip
Hi netsonic,
In Segment 1 with link elements try to use 0.0, 0.5, 1.0 for the x-axis.
For more information about RMv11.13, please look at the below link:
communities.bentley.com/.../275603
Ana Carla Peres
Senior Technical Support Engineer
Bentley BrIM
Answer Verified By: MarcosBeier
Hi Ana,
Where can I input "0.0, 0.5, 1.0 for the x-axis", I tried to input them in htab1, but it doesn't work
BTW: The TCL is attached in the top thread
Hi, It should be necessary to divide the link element too, as link elements can assign only cross-sections at the connections, begin and end of the element.
I can look at your file, but I need to create one service for answering you, Can you send me your email address please to anacarla.peres@bentley.com. Thank you.
communities.bentley.com/.../steel-tied-arch-bridge
netsonicyxf@gmail.com
The full TCL is attached.
Thank you
Link.zip
Thank you.
I'm going to investigate your file and come back to you through SR 7001409176.
Best Regards,
