How do you update a Functional Component (Custom Pier or Abutment)?
This is a long one, but it's been bugging me for a while and I strongly believe this needs to be improved.
I have created a .cel to use as a functional component for a custom pier or custom abutment. This cell has 2 columns. I have placed this cell into my bridge model using the Place Custom Pier tool. It's working well. However, I've just noticed that I need to have 3 columns instead of 2 columns. I open my .cel file, and edit the cell to have 3 columns.
In order for me to update the pier in the model I need to do the following:
  1. Open the cell, and edit it as required.
  2. Delete all custom piers
  3. Compress Options
  4. Close the dgn file
  5. Reopen the dgn file
  6. Use the Place Custom Pier tool to re-place all the piers I had already placed
  7. I might have modified some of the variables for individual piers as well. So I'll need to go through each pier and update these again.
  8. I might have had to change some individual piers active angle, horizontal offset, vertical offset or cap lengths to suit specific project requirements at certain pier locations.
There are some obvious issues with this workflow.
  • It's making me re-do work that I've already done (placing piers)
  • This entire process might take an hour. All I wanted to do was add a single column to my existing piers.
  • This is also a highly error prone and manual process since its relying on me remembering any modifications I've made to individual piers.
Coming from a background using Revit, I believe Functional Components should behave the same way that families behave in Revit. In Revit I would create a family for a pier, and load that into my bridge model. If I ever need to change that pier then I can simply select that pier in my model, select 'Edit Family', make my changes in the family file, and then load it back into the project, and all the piers update automatically. It's logical that there is a link between the family and the main bridge file. But in OpenBridge, there is no link between the cell file and the main bridge file.
Here is a detailed explanation of Revit families for those not familiar: https://blogs.autodesk.com/revit/2018/08/27/understanding-revit-families/#:~:text=Simply%3A%20the%20family%20contains%20the,and%20defines%20the%20element's%20parameters.
In my opinion, this is exactly how Functional Components should work, and I simply cannot see a reason why someone would prefer to work with Functional Components with the way they currently work. I assume it is a limitation of previous OpenBridge/Microstation functionality with how cells operate rather than a workflow choice from Bentley, because it doesn't make logical sense.
If Functional Components are given the ability to update in the same way Revit families do, the power and usability of OpenBridge will be hugely improved.
  • Hi Colby,
    I am thinking you need to create the parametric model with your expecting behavior before place the custom abutments or piers.
    For example, you generated the each custom piers by numbers of columns(2-columns, 3-columns pier)
    But you can define the scenarios that numbers of columns through the Array parametric solid feature in MicroStation or OpenBridge.
    Also, In the bridge site you need to place same substructure but different dimensions and numbers of columns. OpenBridge allow you will define the substructures using one parametric cell.
    Please let me know I will be able to show you the beauty of parametric technology in Bentley.
    Thanks.
  • Hi Yujin,
    I understand your approach, but the problem is that you can't account for every possible design change that will occur in a project simply by using parameters. Say I'm doing the modelling and the engineer decides to add lateral restraints to the headstock, or they decide to add a recess halfway up a column, or they want the footing to have chamfered corners, or they want to split the footing from a single large one into multiple smaller ones, or the piles change from concrete to steel, etc, etc. For every one of these changes I'd need to completely rebuild all the piers because there is just no way to allow for all of the possible changes in a design using parameters.
    During the early stages of a design project should I really be spending more time building a fully parametric pier that covers every possible design solution? If I'm just trying to deliver a 50% design set, it should be something that starts rough and as the project develops it becomes more refined.
    The problem is that the functional components don't fully allow for the flexibility that is required in a real project, where you change things multiple times during the design phase. When these unknowns come up on a project (which they do every time), it requires re-modelling.
  • Hi Colby
    As you know BIM software companies(Bentley and Autodesk) will not be satisfy of engineers expectations. because there are lots of substructure types in the world.
    At this moment, You have several workarounds.
    First one is create full custom substructures but you don't need to generate it completely. just update the model with additional constraints and save as different file name.
    Second way, create custom substructure using variable pier templates.
    Third way, generating the independent custom components with your available scenarios. and place to your bridge model.
    but you need to place the components three times to complete your substructure.
    Last way, combine OpenBridge and custom components for your substructure.
    Generate OpenBridge template with dummy column and cap to utilizing OpenBridge footing components and place custom cap and columns.
    Also, OpenBridge team has hearing your voices to enhancing the workflow to more flexible between existed bridge components and custom components.
    Thanks.
  • Hi Yujin,
    I would like to ask if it is possible to develop own xml library with components like caps, columns, footings, etc. that would functioned the same as official components available within OpenBridge? This task is certainly meant for software developers not regular users. Does OpenBridge allow for such upgrade based on custom and standards in different countries? It is obvious that Bentley alone can not cover all possible shapes and varieties used all around the world but development companies can bridge this gap.
    One Example:
    There is a rectangular footing in substructure template where user can opt for slopped upper face but that slope with regard to reinforcement is done impractically. See image.
    There can be several others examples where just a small change can be needed and user is forced to use custom cells and then loosing features like reporting, generating excavation, footing depth based on terrain etc.
  • Hi Tomas,
    At this moment, we can't have the xml file directly.
    But I would like to suggest you the workaround with GenerativeComponets.
    Generating GC package files for each components for footing, column and cap. And create a gc package file for substructure that will be used to OpenBridge Modeler.
