Hello there, I created two new sections from TYPE-IV AASHTO template to make my bridge girder wider at the supports, but I dont know what I'm doing wrong. As you see in the image, in the region where the section transition occurs, the software is misplacing my referrence points( the height of the P3 is the same for both sections, but in the transition portion, the software places this point a lot heigher, as can be seen).
Thanks a lot
Hi Diego,
Some reference is mixed up for sure.
I'm assuming you created them according to the best practices from the link below, right?
I'll take a look at it in the SR 7001411783 and let you know.
Marcos Beier
Senior Technical Support Engineer
RM Bridge - OpenBridge Designer RM Bridge is now an integral part of OpenBridge Designer CONNECT Edition as Bentley’s solution for supporting the design and engineering tasks in bridge construction for all types of bridges and construction… Last edited 1 day ago in LARS | LEAP | OpenBridge | OpenTunnel | RM > LARS | LEAP | OpenBridge | OpenTunnel | RM Wiki
Thanks, Marcos, I'm looking forward to that. Meanwhile, where can I follow this service request ?
I thing I cant acess "My service requests", maybe because I have a educational subscription?
Hi Diego, yes, the educational subscription has fewer rights of access. But, when needed we can exchange additional information by e-mail.
