In LEAP Bridge Steel is there a way to model a beam that is angled at the splice points. The bridge deck is curved but the beams are straight between splice points turning 1-3 degrees at each splice. I need the same member group to run from abutment to abutment but be turned as it goes through each splice.
For the beams to be straight and deck to be curved then you can try to assign the Girders using Custom Beam Path option.
https://communities.bentley.com/products/bridge_design___engineering/w/bridge_design_and_engineering__wiki/56503/lbs-custom-beam-path
But currently it is not possible to have splice points turning 1-3 degrees at each splice.
These are the only options available when the user wants to model the girder .
