OpenBridge Designer CE 2021 Release 2, GenerativeComponents 10.09.01.06
Node types is blank, hit "Graph" or "Transaction", no corresponding window shows up.
The GC teams says:
"The Civil GC is having issues, i would request you to report these to the concern team as Stuart has mentioned earlier."
communities.bentley.com/.../710535
OpenBuildings Generative Components Update 8(10.08.00.40) has been released. 934 views Node types, Graph and Transaction doesn't show up +1. 323 views.
MyeClass
You could try launching GC from within OpenBridge Designer (in the Interop. menu). I'm not sure if that will give a different result.
We knew this issues. You won't see the icons when you open the created file.
Also, It will update to feature version. At this moment, There is workaround.
(1) Create a file with dummy file name.
(2) Open the created model file.
Thanks.
This was resolved here:
Node types, Graph and Transaction doesn't show up - GenerativeComponents Forum - GenerativeComponents - Bentley Communities
Mark
OpenRoads Designer 2023 | Microstation 2023.2 | ProjectWise 2023
