I am trying to model a bridge that has two abutments and five piers. I have two beam groups (one with 7 beams and the next with 8) that changes at the middle pier. At this point I need the deck to have a gap 20" wide, which is filled with a joint filler in the field but is not continuous in respect to strength. When I try to leave this gap my model fails. Any recommendations
Hi Micheale, log a service request and attach the model for further investigation.
Thank you.
communities.bentley.com/.../how-to-log-service-request
Ana Carla Peres
Senior Technical Support Engineer
Bentley BrIM
Are you modeling this as two separate decks? Or what method are you using to create a gap?
