Hello there. I'm trying to create an box girder, but I'm not able to do so. As shown, the ok buttom is disabled.
You probably have a bridge with the same name in that file. Try changing the bridge name or start with an empty file.
Answer Verified By: Diego Veloso
Try to fit the view.
communities.bentley.com/.../now-available---openbridge-modeler-connect-edition-2021-release-2-march-2022
Ana Carla Peres
Senior Technical Support Engineer
Bentley BrIM
Hello, Steve. Indeed that was the case, but do you know how can I see like the list of my bridges in my file? Because I had created a bridge with the same name but that bridge was later deleted, so I thought the name wasnt in use.
