The client request us on consideration of foundation/structure interaction in full bridge model. Please be asked how can I model of soil-structure model as for Soil Structure Interaction analysis(SSI) by directly model in RMBridge without using of Openbridge Modeler(OBD). I understand that if the model generated by OBD and transfer to RM can do that but that is not our look for since some limitation.
Thanks in advance.
WinaiG
Did you get any fitting solution?I am other than confronting a relative issue.
epayitonline.com
Hi Winai,
For Soil-Structure Interaction analysis please check the information at the links below and access detailed information and models in RM Bridge.
Marcos Beier
Senior Technical Support Engineer
RM Bridge - OpenBridge Designer RM Bridge is now an integral part of OpenBridge Designer CONNECT Edition as Bentley’s solution for supporting the design and engineering tasks in bridge construction for all types of bridges and construction… Last edited 23 hours ago in LARS | LEAP | OpenBridge | OpenTunnel | RM > LARS | LEAP | OpenBridge | OpenTunnel | RM Wiki
Hi, MarcosBeier,
Thanks for your information. However, as illustrated in link you attached, that's generated model by using OBD and transfer to RM. Do you have some recommend what's structural element types , tool(s) and workflow to be used if we generate model in RMBridge directly, not by OBD??
Winai
