Dear All,
I have modeled a PSC voided slab bridge (full staging construction method). Below is the plan view of tendon placement for the main girder.
There is an issue related to the tendon definition. For example, tendon no. 3213 (shown by black arrow above).
In the plan view, it's normal in terms of position of this tendon. But by the 3D view function of the program, it shows something strange.
My questions are
1. Why the tendon is far from the girder section boundary?
2. What is the different between the two positions (pink and red color) shown above for the tendon ?
The TCL file is attached in this link below
mega.nz/.../TVFHRABL
Can anyone help me?
Thanks in advance.
khuduba
The issue with the tendon position may be related with some variable definition, I'm going to look at your file.
Could you please send me one email to anacrala.peres@bentley.com for after answering you.
For more information about RM Bridge software please look at the links below:
communities.bentley.com/.../rm-bridge-connect-edition
Ana Carla Peres
Senior Technical Support Engineer
Bentley BrIM
Hi Ms. Ana Carla Peres
Thanks for your quick response.
Fortunately I myself can fix the issue now. The problem is the local direction (x direction) of the main girder. It should be the same direction with the global X direction.
Yes, that is right. Glad to know the issue is solved.
Any other question, please don't hesitate in contacting us again. You can use my email for it.
