After setting up both Text Styles and Dimension Styles multiple times, any time I try to change the text within a dimension the style is converted to Style (none). This happens immediately after placing any dimension in any style, after directly changing the text style, updating from library, and all other forms of manipulation I could think of. This occurs on all Workspace/Worksets I have used. Any support on how to make the text style match what is specified in the Dimension Style would be very much appreciated!
I also recently noticed this using MicroStation Connect, as well as OpenRoads Designer. I haven't been able to determine why the text style is set to none when editing dimension text. As you noted my dimension style has the Text defined with a Text style. We've had difficulty when manually editing dimension text with stacking fractions when the text style is set to none. It happens manually editing any dimension text.
Hopefully someone (Bentley) has an idea.
ORD version 10.10.21.04
MicroStation Connect version 10.16.03.11
I have also been having this issue. Has anyone found a solution?
try to have the text styles and dimension styles in two separate dgnlibs.
As i know it's possible that the dimension style itself is corrupted. Try creating a new dimension style from scratch and apply it to the dimensions to see if the issue persists. If the problem is resolved, it indicates that the original dimension style was indeed corrupted.
PrepaidGiftBalance Visa
