Dear Mrs./Mr.
In my calculation, I'm using RM-Set to plot SIGI principal stress of concrete box girder. As the results plotted, I observed that there is some elements (el. 124, 127, 157 & 160) has a confusing principal stress result, SIGI princ. stress of thóe elements are very large in compare to adjacent elements, although these elements have similar section properties and internal forces.
After checking PrincLC results, section properties etc. I can not spot any irregular data, so I don't have any idea why principal stress results are so confused, can you please check my model and give me some advices, thank you.
Hi Tran, I'm going to investigate your file. Could you please send me one email to anacarla.peres@bentley.com for after answer you. Thank you.
For more information about RM Bridge product, please look at the links below:
communities.bentley.com/.../rm-bridge-connect-edition
Ana Carla Peres
Senior Technical Support Engineer
Bentley BrIM
Those are transition elements from the hollow box to the support cross-section.
Top & Bottom Point Stresses might be a better reference due to the discontinuity.
Marcos Beier
