LEAP Concrete Column in Tension
Hi. My hand calculations show that my concrete column will go into tension for my earthquake loading, but the my LEAP Concrete Diagram for the column doesn't show anything for the interaction diagram for a column in tension. Is there a check box that I need to click for the column to show the tension portion of the diagram? It would also be nice if the Moment Demand and Axial Demand were stated as text possibly in the top right corner because if the moment/axial demand is too high it doesn't show up on the chart and you don't know what capacity you are trying to achieve.
Also for the column design report I understand that currently it shows the minimum computed ratio of (φMn/Mu) of all combinations, but I would like to request that a row for maximum axial load and minimum axial load be added to the table. This is the table that I think could be be expanded.
Thank you
Parents Reply Children
