Using 2021 Release 2. For some reason the Apply Skew to Solid option only shows up on some piers. The first screenshot has a rectangular cap and shows "Apply skew to solid", the second screenshot has a tapered cap and doesn't show this option. Does this impact the ability to apply the skew? Can we only skew the ends of rectangular pile caps? Can this be an enhancement request?
Is the best workaround in the mean time to use the "Trim Solid" tool to get the skew correct?
Thanks for your help.
Hi, the "Apply skew to solid" option is not available for piers with tapered caps. Yes, the best workaround is to cut the solid using MS tools.
I will log an enhancement ticket for your request.
Answer Verified By: Colby Gallagher
