I'm trying to model a bridge which is very usual in Spain, prestressed concrete slab with variable edge and circular holes to make it lighter (see pictures below)
Section with minimun edge, situated on center of span and with circular holes.
Section with maximum edge, situated above columns and without circular holes
Longitudinal profile, you can see the variable edge and that circular holes are not along the full length of span
It is posible to insert these circular holes in a deck template to define it with constraints and not in the whole span of the bridge?
I have to model it with open bridge modeler and send it to RM bridge.
Thank you so much in advance.
Hi Javier,
Yes, you can do it in OBD.
1st use OBM, create a CIP Bridge Type and insert one advanced deck:
2nd sent it to RM Bridge:
If you have any other question, please send me one email: anacarla.peres@bentley.com
For more information about RM Bridge, please look at the below links:
communities.bentley.com/.../rm-bridge-connect-edition
Ana Carla Peres
Senior Technical Support Engineer
Bentley BrIM
Answer Verified By: MarcosBeier
Hi Ana!
Thank you so much, advance deck works !
But, it is posible to define circular holes while drawing the deck template and introduce constraints to define with variables e.g. its center, radius or diameter?
Yes it is possible to use variable constraints in advanced decks and after they will be send to RM Bridge, too. Variables need to be defined in the deck template. And in Place Advanced Deck, you have one specific table only to introduce the functions that will be used for the variables constraints.
For more information about OBM please look at the links below:
communities.bentley.com/.../openbridge-modeler-connect-edition
Hi Ana.
Yes, I know it is possible to introduce variables in deck templates in advance decks, I've done for different dimensions like slab variable thickness or deck's width, and I could use it yesterday with advanced deck to define the bridge deck geometry.
But, if I draw a circle when I'm drawing deck template, I only can define variable constraints for center coordinates, not the radius or diameter and, even in the modeler I can move the center coordinates, when I send it to RM the circular hole stays on the original position I've drawn when I draw the template.
So, my question is, how do I have to draw the circular hole when I'm drawing the deck template to define its radius or diameter and its centre as a variable constraint that RM Bridge can recognise correctly?
Thank you so much.
Regards.
