LEAP Steel: Ending a girder before CL of bent
Is there a way to define a girder end distance from the centerline of the cap? By default, LEAP Steel takes the span length as the length of the beam. My DOT requires 3" clearance from face of inverted T stem (or centerline of rectangular bent). When I try to change the beginning of the beam definition and/or length of the beam under "Member Definition," I get a bunch of errors. Attached is a figure to show what I currently have modeled.
Thanks!
Parents Reply Children
