Hello, I,m trying to create a Bent where 2 separate bridges meet, is this even possible to model in Openbridge Modeler? Ultimately, I want to transfer the model to LEAP to run the analysis.
OBM -- if the 2 separate bridges are on different substructure and are meeting then this can be modeled in OBM as 2 different UNITS.
In this case each unit will be exported to leap as separate Bridges.
OBM -- If the 2 separate bridges are on common substructure then it can modeled in OBM as a single unit and exported to Leap.
For more information related to adding units in OBM please check the wiki articles in the below mentioned Bentley Communities link.
https://communities.bentley.com/products/bridge_design___engineering/w/bridge_design_and_engineering__wiki/51794/add-units-to-existing-bridge
You are welcome.
i'm glad the solution helped you in resolving your issue.
