Hello, I am Ranjit from Sagar Steel Corporation
I've seen some videos that show Itemtype is attached to elements that can report a lot of element properties within OpenBridge, and I've read the wiki on this page that itemtype information cannot be transferred to itwins, but I'm wondering if I copy the OpenBridge Solids to OpenBuildings or Microstation, will I be able to see Itemtype information on 3D Solids or will the data be lost? If it is not currently possible, do you know when the next release of OpenBridge Modeler will be available?
It is expected to happen soon, once it was already announced.
communities.bentley.com/.../coming-soon---openbridge-modeler-connect-edition-2022-release-1-september-2022
Ana Carla Peres
Senior Technical Support Engineer
Bentley BrIM
Sagar Steel Corporation, you don't need to copy the same question and put it again, you can click on "I have the same question" and you will receive updates.
Refer to original question - communities.bentley.com/.../openbridge-modeler-itemtype-export
Jaimin Patel
