Hello there.I would like to get “span name” of Deck by using expression and show it in properties ,just like showing “Span name” of BeamSegment in Fig.1.
Figure.1
For this purpose,I tried to use an expression which is "this.GetElement().Deck_SpanName" in Fig.2.But it failed finally.
Figure.2
So I'm here for help.Thanks!
For the Deck Item Type there is no expression for the Span Name.
The deck is typically cast/poured continuous over multiple spans, hence there is no concept of span name for the deck. If you model a different deck for each span, you could name the deck with the span # attached and get the deck name as an Item Type.
Hi Sri.Is it possible to get the starting and ending mileage stations of deck?
Hello. Not possible at this time. Will try to add for the next release of OBM.
Thank you.Looking forward to the next release.
