Hi
The queation is in the Subject;
Is Open Tunnel an own application or is it only a combined word for a lot of applications (Open roads, Open rail etc.)??
Tom
OpenTunnel is a completely new own application, not a bundle of previous software. You can find more information about it at the links below:
Marcos Beier
Senior Technical Support Engineer
RM Bridge - OpenBridge Designer RM Bridge is now an integral part of OpenBridge Designer CONNECT Edition as Bentley’s solution for supporting the design and engineering tasks in bridge construction for all types of bridges and construction… Last edited 2 months ago in LARS | LEAP | OpenBridge | OpenTunnel | RM > LARS | LEAP | OpenBridge | OpenTunnel | RM Wiki
Answer Verified By: Tom
Hi MarcosThank you for the information, When do you think there is going to come an example of station tunnel area creation video, that would be interresting to see how Open tunnel handles that also. From tunnel to station back to tunnel.
Hi Tom,
While you can model an underground station in OpenTunnel using the Microstation solid creation tools, it would be better to use OpenBuildings Designer for such elements. OpenBuildings has the capabilities to model and design such structures by using parametric relationships between different objects. You can then have a federated model where you will reference the underground station and the tunnels.
