I would like to place barrier rail off the deck and on a wingwall. The program wants me to put the rail on the deck. I cannot horizontally offset the rail off the deck either. Best I can do is have the rail at the edge of the deck (Approach Slab) but that is wrong. I also tried extending the rail on the bridge deck but to no avail. How can I place the rail on the wingwall? I am using version OpenBridge Modeler CE 2021 Release 1 10.10.0.85. Thanks for the help.
After placing the barrier on the deck (Approach Slab), you can use a negative Horizontal Offset to adjust the location of the barrier relative to the path it is following. In this case, I have offset it -1.000', which allows it to line up with the barrier on the bridge deck. To get the barrier to end at the correct length, you can also modify the start/end station offset. (OBM 2021 Release 2 10.10.20.91)
