I am following the "Deck Overhang Loads" help page to input my deck overhang and construction loads into the "Deck Placement Sequence" window.
I am then double checking that my loads are creating the correct lateral moments using the equation below and the tables in the analysis "Construction Lateral Moment" report.
So far, so good - these unfactored moments exactly match what my hand calcs give me.
But then, when I go to check fl in the Constructibility code checker, I can't get it to match. I am even using a 1.5 load factor on the construction moment due to the AASHTO Article 3.4.2.1.
Can you confirm the load factors that are applied to the lateral moments when calculating the lateral flange stress for the constructibility checks?
You are welcome.
I'm glad the issue is resolved.
