When trying to get to place reinforcement in a concrete deck using ProConcrete within OBM. I get "Command not Defined for this application." I am using OBD Version 10.10.20.34 and have placed the "Slab with Constraints - 2 Lanes" loaded in into the model. Please to not suggest "upgrade to the latest version of OBD as an answer! Sometimes that is just not possible. Thank you!
The "Slab Reinforcing" tool doesn't work for decks that follow curved alignments. Is this your case?
My structure is not curved.
Can you send me your files? vlad.ursachi@bentley.com
You should be able to use the custom reinforcing tools for the deck reinforcement. For decks, I typically use the extract edge tool to get my guidelines or starter rebar shapes.
I am trying to do custom reinforcing tool but I am not using that tool what to do now? Rebaid
