I'm attempting to use the Variable Constraint window to make the shape of a barrier rail vary along the length of a single span. I made a template for the barrier rail, where I defined all of the constraints I would need to adjust:
I placed the barrier rail where I needed it, opened the variable constraint editor window and put in all the constraint ranges for the different variables:
This is how it says the fully constrained sections should look in the "template view" section:
After clicking OK, nothing changes visually, though it appears to break all of the parameters on the barrier template - I can change the begin/end offsets, the vertical/horizontal offsets, etc. and nothing further happens. The only way to get it working normally, again, is to delete the barrier rail and re place it.
Hi Nicholas, could you please log one service request and attached the file for further investigations?
Ana Carla Peres
Senior Technical Support Engineer
Bentley BrIM
