Calculating PNA of curved tub-girders for Eq. 6.10.7.3-1 in LEAP Bridge Steel version 22.00.02.19
In the article below it mentions that the issue where "Distance from top of concrete deck to the neutral axis of the composite section at the plastic moment was incorrectly calculated." is fixed. However, I'm still running into this problem when designing multi-span curved steel tub-girder unit. Is this still an issue? Or maybe I'm missing something?
It looks like the program is not considering the section to be composite, although I have defined the members to be composite throughout the length under the Shear Connector Locations. AASHTO ductility check Equation 6.10.7.3-1 is failing no matter what section dimensions I define. I have calculated Dp by hand and confirmed it with another software (MDX) while LEAP is calculating much bigger values, as if ignoring the deck slab.
I'm using OBD version 10.11.00.40 with LEAP Bridge Steel version 22.00.02.19.
https://communities.bentley.com/products/bridge_design___engineering/w/bridge_design_and_engineering__wiki/62506/enhancements-and-corrections-in-leap-bridge-steel-version-22-00-02-19-part-of-open-bridge-designer-version-10-11-00-40-september-2022
Thanks.
