Hi
I am looking to design a square column on a drilled shaft/Caisson however the square column size is larger than the caisson and would like to introduce a circular longitudinal reinforcement pattern in the column, so it sits well into the drilled shaft along with sacrificial reinforcement for the square column on the sides. I want to do that since I have seismic concerns demand. I wanted to know if that is possible in LEAP/RC Pier. please suggest.
There is an option for the user to assign the rebars in Circular manner.
Then the user can input layer 1 and layer 2 rebars.
But currently there is not option to input sacrificial reinforcement for the square column on the sides.
Please let me know if this is the information you are looking for.
