Hello ,
OTD seems a promising solution for tunnel design. For us working with openBim, do we have the possibility to export to IFC ? When it comes to adding customized attributes how can this work and finally, what about issue management (BCF)?
thanks!
1. Export to IFC directly from OpenTunnel is not supported in the current version. An export from ifc can be done from iTwin i.e. send OpenTunnel to iTwin and from there export to ifc.
2. Customized attributes will be able to be defined automatically trough item types in the next version of OpenTunnel. You can add item types in the current version, but manually for each solid.
3. Issue management can be handled through iTwin Design review.
Answer Verified By: MarcosBeier
Open the OBM bridge model file and click on Collaborate from OpenBridge Modeler workflow and select. Open Tunnel Designer IFC export , attributes and BCF.www.clover.com
