I modeled my bridge (a skewed slab bridge with its supports and bearings) with OBM and then tried to send it to RM-Bridge (in Open Bridge Designer),
but the software did not allow it (see attached captures).
Is it because of the type of piers or abutments I used or else?
Thanks.
Hi Kamel, Thanks for the files.
One solution can be to generate one second axis throughout the bridge structure, due to the wide eccentricity of the road alignment.
After send this model to RM Bridge:
Due to the high skew angles, it may be necessary to check bearings position and deck CS properties and adjust them in RM Bridge, if it is the case.
Best Regards,
Ana Carla
Ana Carla Peres
Senior Technical Support Engineer
Bentley BrIM
Answer Verified By: MarcosBeier
