How do I control the spacing of the ledge reinforcement for an inverted T beam? I do not see a dialog box, I'm using LEAPBridge Concrete V 21.00.00.24.
Please select the concerned BAR and Spacing and then change the spacing and click on Modify and recheck the design results.
Please see the screenshot.
For more information related to Leap Bridge Concrete program - Inverted Tee Beam Ledge Reinforcement please check the wiki articles in the below mentioned Bentley Communities link.
https://communities.bentley.com/products/bridge_design___engineering/w/bridge_design_and_engineering__wiki/26050/inverted-t-beam----ledge-reinforcement
Inverted T-Beams are prestressed concrete elements that have a constant cross section. They are manufactured using high tensile strength prestressed wires or single wire which are embedded within the element.Portal 4 Me
Hello, I have a related question. The program appears to not recognize multiple layers of the Bars N, despite it being allowed per AASHTO:
My Input vs. Output:
Perhaps I'm missing something in the program input and/or in the code.
Thanks in advance.
Edit:I even moved them up to be sure they are in the top 2/3:
Same result:
