I am running into issues when I open LEAP Bridge Concrete CONNECT Edition v21.01.00.22.
I get an error stating "LBC library is not set or has invalid location".
When I browse to the Preferences tab, it appears that all of the paths to the different libraries are set correctly.
Please advise. Thanks,
The solution for this issue is to set the path correctly and the warning message will go away.
For ABC data set files.
C:\ProgramData\Bentley\LEAP Bridge Concrete OBD 10.11.00\Lib
For Library files.
For information related to Library path , please check the below mentioned bentley communities link.
https://communities.bentley.com/products/bridge_design___engineering/w/bridge_design_and_engineering__wiki/54662/where-is-the-consolidated-library-of-leap-bridge-concrete-located
If you are still facing issue, then please create a service request and one of the technical support engineer will look into the matter.
Please let me know if you need any additional information.
Vinay
Hi Vinay, I set the paths correctly and the warning message doesn't go away. Bentley needs to do something about this.
Please post the screenshot of Preferences Dialog Box
I. This happens when LeapBridge Concrete OBD 10.10 starts.
II. Then I get a second warning once I click OK.
III. If we open the Preferences Dialog Box we can see the paths are set correctly.
IV. And if we go to that path we can see that all the files are there.
Thank you for the screenshots .i'm looking into this issue and will get back to you.
