Hello,there!
Such as a skew bridge, the end diaphragms are not orthogonal to the girder.How to model?
Thanks!
Hi, You define support lines with different skew angles.
If you want, you can log a service request attach the file and we can help you modelling it. Best Regards,
communities.bentley.com/.../how-to-log-service-request
Ana Carla Peres
Senior Technical Support Engineer
Bentley BrIM
Thanks for help!
But the crux of the matter is that variable cross-section beam segment and diaphragms with oblique beam ends cannot be created in the specified direction.
As shown in the figure, the beam and support line are diagonal, and we want to adjust the cross-sectional direction of the beam to be consistent with the direction of the support line, rather than always perpendicular to the beam direction. At the left end of the beam, we create the variable section, and the actual variable section segment should end flush with the cyan line, not the white line as in the figure.
This model is uploaded as an attachment.
斜交桥梁.dgn
Thanks for checking my problem!
Unfortunately OBM is not able to deal with this situation currently. All sections are extruded normal (along the white line) and the solids are cut by the planes along the skews.
Can you create this service requests?This function is really needed in modeling skew bridges.Thanks!
