I'm looking for software that I could use to create 3D precast bridges with and create shop drawings to detail rebar placement in all the precast elements. Not sure which one would be the best to use. The software needs to be able to handle the following items:
- Mix different section types, CPCI (I Girder), Box Girders, NU Girders.
- Incorporate precast partial depth deck panels with a CIP deck on top of that into the design software.
- Integrate deck sections into the top flange of a precast girder, like a 2m wide top flange.
- Add dowel pockets, threaded inserts and bracing holes into the web of girders.
- Include embedded plates in the bottom & top flanges and the sides of bottom flanges. What other embedded hardware is available?
- Combine concrete girders with steel truss type Intermediate Diaphragms.
- Flare the girder spacing.
- Partially skewed girder ends, from the web face to the top flange tip.
- Add shear keys to the girder sides / ends.
- Customize the shape and size of the curbs / gutters and sidewalks that the design software uses.
- Add Bracing / Shoring for the girders.
- Add sandblasting lines at girder ends that are cast in.
- Create formwork.
- Calculate camber without including the deck.
(We check what the bearing pad contact will be when the girders are placed.)
- On bridges with a slope of 3% and greater the ends of the girder are tipped in like a parallelogram so when erected the end face is vertical. Is it possible to do this and would it also be possible to skew the ends of that same girder?
- Design Post tensioned structures.
I have searched the forum's, but I have not been able to find information on the above items. It could be that I am not using the correct / same terminology in my searches. Any information you can provide would be great.
Thanks.
I would suggest you to look into the Open bridge Design program and check RM Bridge module and that should cover all the requirement you have posted in your query.
Please check the below mentioned link for more information related to OBM and RM Bridge.
https://www.bentley.com/software/openbridge-designer/
https://communities.bentley.com/products/bridge_design___engineering/w/bridge_design_and_engineering__wiki/48336/openbridge-designer-onboarding-guide
https://communities.bentley.com/products/bridge_design___engineering/w/bridge_design_and_engineering__wiki/15934/rm-bridge-connect-edition
