Hello, I would like to know how the lateral beam spacing is measured in Leap Bridge Concrete when the beam is not symmetrical. (Example: Beam C.G. to Beam C.G. or center of the web to center of web or some other method)
HI,
In my investigation i added a symmetrical girder and then checked the Beam spacing.
Then i changed the first girder and then added a Non Symmetrical glider then checked the beam spacing and the spacing remained the same.
Based on this i can say that the program i calculating the spacing from center of the web to center of web.
For more information on related topics , please check the below mentioned link.
https://communities.bentley.com/products/bridge_design___engineering/w/bridge_design_and_engineering__wiki/26005/flared-and-skewed-bridge-girder-spacing
