I am fairly new to OpenTunnel Designer and have the following problem:
1 week ago I imported a IFC4.3 underground model created and exported in Leapfrog (same company - so it should be compatible). Everything worked.
This week I created a completely new project and did everything exactly the same. But as soon as I import the IFC in the very first step, nothing shows up, which is strange because the .dgn project data got bigger after the import and I can see each layer of the subsurface model in the layer manager. But when I press "fit view", nothing is displayed or I can't find it.
Hi Stefan,
Is this your 2d or 3d model? Is there a "Default-3D" model that it imported it into?
Mark
OpenRoads Designer 2023 | Microstation 2023.2 | ProjectWise 2023
Its a 3D Groundmodel made with Leapfrog.
So I digged a bit deeper into it:
Leapfrog just got an update, since then the ifc import doesn't work anymore or at least dosn't display the model in OTD.
There is a "GM"(Groundmodel) Soil-Layer:
which causes a weird "infinite-crosshair" which only goes away if I disable the layer itself.
Its hard to explain so I made a video of it. I do think that its the leapfrog update which casuses all this. A older version of my IFC-Groundmodel works perfectly fine.
