Hello, I have a couple questions regarding OpenBridge Designer (LEAP Bridge Concrete Substructure).
- How is the thermal force calculated for a multi-column bent with elastomeric bearing pads with varying column heights?
- Also, how is the out-of-plane stiffness calculated for a multi-column bent with varying column heights supporting girders on elastomeric bearing pads?
- Lastly, how is the out-of-plane stiffness calculated for a multi-column bent with different column and drilled shaft diameters to the point of fixity?
Danny V
Please check the calculation for fixed bearing and for elastomeric bearing pads , the calculation is similar.
Very detailed theory related to thermal force calculation is shown in the RCpier Tutorial Manual.
https://communities.bentley.com/products/bridge_design___engineering/w/bridge_design_and_engineering__wiki/23321/thermal-force-calculation-for-fixed-bearing-condition
Vinay,
That's not the answer im looking for. I'd like to know how the program calculates the out-of-plane stiffness when more than one column is modeled with varying heights and different column and drilled shaft diameters with elastomeric bearing pads. Can you please explain. The screenshot provided is not explaining that.
Hi Danny ,
Please email me your official email to "Vinay.Mysore@Bentley.com".
Thanks ,
Vinay
Did Danny's questions get resolved? I too wondered how RCpier handles varying heights.
I created the Service Request: 7001531346 and emailed you the answer.
No. It was never answered
This was response provided to Benji Michael:
This is the response from the Software Development manager .
“I made a quick model to test the out of plane (OOP) loading and the effect due to that. Following are some snapshots of the model. I have attached the file also in here. In the engine source code it clearly shows the element stiffness matrix considers the moment of inertia about the minor direction that is aligned to the OOP direction. Both along transverse and about OOP moment DOFs are considered in the stiffness formulation. Stiffness terms are exactly the way Timoshenko has provided.
Please let me know if this is the information you are looking for.
Please let me know if you need any additional information.
Thanks & Regards,
