I am working in LEAP through the OpenBridge Designer BIM workflow. I have changed the concrete strength for an element in OpenBridge Modeller, but it isn't updating in LEAP Concrete. Please advise.
OBM
LEAP
If the user is using the BIM workflow then the program is updating the concrete strength.
Please follow this procedure.
1 ) change the concrete strength.
2) Then click on Update Analystics.
3) Then export to LBC and check the concrete strength of substructure.
Please check the communities link for more information related to BIM workflow.
https://communities.bentley.com/products/bridge_design___engineering/w/bridge_design_and_engineering__wiki/51857/bim-workflow
If the user is using the stand-alone procedure, then the program is NOT updating the concrete strength as the program creates multiple LBC files whenever exports the updated model to LBC.
Please check the communities link for more information related to standalone workflow.
https://communities.bentley.com/products/bridge_design___engineering/w/bridge_design_and_engineering__wiki/51371/standalone-workflow-for-analysis-and-design
https://communities.bentley.com/products/bridge_design___engineering/w/bridge_design_and_engineering__wiki/55093/how-to-create-a-standalone-substructure-or-superstructure-only-model-in-obd
I am working in the BIM workflow. I have followed recommended procedure and I'm still getting the same issue.
Please advise.
Hi Dylan,
Please email me the file so that i can test this issue on my machine .
My email ID is "Vinay.Mysore@Bentley.com" .
I shall create a service request and will email you the number to track this issue.
Thanks ,
Vinay
Vinay:
Perhaps you could teach the many Bentley roadway folks your manner of resolving issues. I am certain that many of us on that side of things would be quite appreciative.
Thank you Mark for the appreciation. Will be more than happy to help.
I know that you are and always have.
