I am working on a single span bridge model in LEAP Bridge Steel. I am noticing that checking the "consider haunch in section property calculation" box in the analysis window does not have in impact on the composite moment of inertia for beam 7. Screenshot is attached for the moment of inertia (circled in black). The model is attached. Can someone take a look at the model and let me know if there is a way to get around it to make the program consider haunch in the section properties? Thanks in advance!
Bridge 384_Griswold Street_Proposed Rehabilitation.lbsx.gz
Hi Subal,
I tested this issue in the current release version V22..... .
It looks like you are working in V20 which is the standalone program.
If you check the screenshot there is a note saying that " Section properties do NOT include Haunch Concrete".
As per my testing --
1) I inputted the Haunch as 0.00 and generate the section properties report.
2) Then i inputted the haunch value as 4.00 in and then generated the report and i could see the change in MOI.
3) Also the note below the table mentions that " Section properties include Haunch Concrete".
4) I had selected the "consider haunch in section property calculation" box in the analysis window.
I would suggest you download and install the current release version OBD V 10.11.00.40
In the older the issue was there and this issue has been fixed in the current release version.
I hope it helps.
Vinay
