Column P-Delta Effects
Hi. When LEAP determines the moment interaction diagram of a column that was analyzed using P-Delta affects does LEAP adjust the moment interaction diagram for the deflections? Such as for a loss of stiffness in the columns due to the deflections as stated in AASHTO LRFD C4.5.3.2?
Or is the moment interaction diagram the same for a column regardless of the deflection?
I'm using OBD V10.10.00.26
