Add Joint to Bridge Deck in Open Bridge
I'm creating a 15 span prestressed girder bridge in OpenBridge Modeler. I need to add a neoprene strip seal joint every 3 spans or so. Can I modify the continuous deck object to add these components? Alternatively, splitting the deck object into multiple deck object could suffice. I would prefer to not rebuild the entire model to add this detail. Any help would be appreciated!
Thanks in advance!
Adam
