I'm in the process of creating plan/profile drawings for a viaduct (160km total - splitting models into >10km length). My bridge is presenting with gaps in the profile view. I'm using the forward view, with display style set as below. I'm using a federated model for my drawing production.
Has anyone experienced this and resolved the issue?
Thanks in advance.
I'm using OpenBridge CE 2021 release 1 (10.10.0.85)
Hi Matt,
Does slightly adding a Cut Offset to the 3d Cut and refreshing it help?
Mark
OpenRoads Designer 2022 R3 (10.12) | Microstation 2023.1 | ProjectWise CE 3.4
Thanks for the response Mark. Yes, unfortunately no difference in presentation.
My initial thoughts were it's to do with the Design File settings, either Resolution or Solids Area limitations. I've kept models to ~10km of viaduct due to these constraints.
Hmm i believe it is simply a 3d slice of the 3d model at the alignment location so it should be showing exactly what it sees. Does it look okay in the 3d model?
Hi Matt Antrobus,
Could it be the lifestyle scale? perhaps, try to turn on the level override and make all level override to SOLID line... just to check whether the linestyle is the issue.
Marcelo
Yes, it looks okay in the 3d model. I've narrowed it down to the display styles. The profile looks fine in wireframe but when switching to visible edges, that's where the gaps appear in the graphics.
