OpenBridge Concrete Substructure - Pile Reaction Calculation
I'm working on an abutment design and am trying to check pile reactions using the bolt/rivet theory as described on the RM Wiki page:  Abutment Design -- Pile Reaction calculation
I have 2 questions:
1) I just wanted to quickly confirm the formula presented on the page is correct:
2) The pile tab output indicates forces used to determine the pile reactions are located at the centroid of the footing. If using the calculation noted above, I get much closer values to the generated pile reactions by applying the load at the centroid of the pile group vs footing.
Many thanks in advance!
MJ
Parents Reply Children
