I am receiving the error message shown below when attempting to send my bridge from OpenBridge Modeler to Leap Steel. The bridge is a two span continuous steel plate girder bridge with a parabolic haunched section at the pier. If I simply change the girders to a rolled beam section the export to LEAP steel works which leads me to believe it is an issue with the how the haunched plate girder is defined. I will keep troubleshooting but any information on the error would be helpful.
As it so often happens, I was actually able to solve this issue not long after posting this question. I had the flanges defined with linearly changing widths even though they were constant width flanges. Changing this setting to "None" solved the issue.
Answer Verified By: Charlie Binder
Please file a service request. ZIP the files and attach the files needed to investigate (include alignment file if bridge is modeled using an alignment from a reference file).
How to log Service Request? - LARS | LEAP | OpenBridge | OpenTunnel | RM Wiki - LARS | LEAP | OpenBridge | OpenTunnel | RM - Bentley Communities
Sorry, I thought I replied to my own post here yesterday but it seems to have not gone through. I was able to fix the error, I had the flange widths set to linearly variable even though the widths did not change. Once I set them to "none" the export worked as expected. Thank you for the response though.
I am glad the issue is resolved. Thanks for the update.
