I have a multi-span bridge that requires a barrier rail transition to an adjacent span that has a larger deck width than the preceding span. I used the horizontal/complex geometry/complex by PI to draw the alignment for the barrier to follow. I tried to use the alignment to guide the location of the barrier, but it introduced unwanted curves in the barrier, which do not follow my custom alignment. How can I force the barrier to follow my alignment without the curves being present? Please see below. I would like the barrier to follow the red lines shown under the grey barrier lines. The other set of red lines are for another barrier to be placed when this matter is resolved.
Band-alignment induced current modulation in Bi2Se3 three-dimensional topological insulator slab has been investigated by quantum transport simulations for three different device designs, one for purely lateral transport and other two with vertical transport. Non-Equilibrium Green Function formalism has been deployed to understand the transport mechanism in band-alignment devices to appraise the possibility of a 3D-TI based resonant device. My Sutter Online
