In the picture shown in the explanation below (in the given link), only cable element and beam element are drawn. However, composite element is not drawn although composite element is mentioned in the explanation. Why it is not shown?How is the composite section made from cable element and beam element in this case? Will it be beam or cable element?
Stress Ribbon Bridge - Cable Compatibility
Best regards,
Ivana
Firstly, we use a structural division method to divide the whole cable-beam structure into inner cablenet system and edge cablenet-beam system. Finite element model is established by ABAQUS. The influence of structure performance of reinforced simply supported beam with cable section, cable sag and initial internal force value was investigated. ManageMyHealth
