Ifc export from OpenBridge
Hi, I have an issue with exporting dgn to ifc and i need that because our client requires it. After I complete my desing model (with use of parametric cels, some smartsolids and terrain), I have attached all Item Types to elements that i wanted and when i go to ProConcreate and start export to IFC - OBM crashes. Is there any guide how export it correctly, I even tried with simple solids that i created with use of modeler tab and OBM stoped working as well. Is there any settings that need to be customized to successfully export model?
Wiktor Mertka
