Does anyone else have the issue if they redefine the deck slab that the slab will overlap another slab even though the begin and end stations are reading properly? Also, when the bridge is analyzed the moment diagrams are reading correctly, so it seems to be a display issue.
Below is my input.
Below are the 2 slabs information that are overlapping.
Hi Dylan, it seems to be graphical issue as you are suggesting. If you are using an older version of LBS please try in the latest version of OpenBridge Designer (10.11.00.40 which includes LBS version 22.00.02.19). If the issue persists in the latest version, please file a service request so that we can investigate the issue.
How to log Service Request? - LARS | LEAP | OpenBridge | OpenTunnel | RM Wiki - LARS | LEAP | OpenBridge | OpenTunnel | RM - Bentley Communities
I tried to file a service request, but my file size was greater than the allowed 20MB file size limit. Is there an email I could send it to?
Service Request: 7001556175 has been filed and further investigation will be carried out to find a solution for this issue.
