When we try to copy the beam sections (BT-54) without changing any properties, the strands layout is disturbed and few of the rows are disappearing.
Original Girder section strand arrangement
Name Changed Girder Section strand arrangement
Top row @ 50.5 in, 46.5 in and 10.5 in rows are missing.
Not sure why the tendons were missing when the copy option was used.
If certain tendons rows are missing then i would suggest you to manually input the extra rows in the library -- Template dialog box.
For more information please check the below mentioned bentley communities link.
https://communities.bentley.com/products/bridge_design___engineering/w/bridge_design_and_engineering__wiki/51502/how-to-add-custom-beam-section-to-library-and-add-height-and-of-strands
