I am analyzing a pier supporting 2 simple spans that are 45 degree skewed. 1. I am confused what offset needs to be entered in superstructure definition? 2. How is this offset playing a role in LL generation? I noticed that changing offset is changing the autogenerated LL on bearings. My superstructure has offset in plan view and also in transverse section view.
Deck Offset Definition : If the pier or abutment is skewed then the offset is defined as perpendicular from the centerline of deck to the centerline of pier.
For more information please check the communities link.
https://communities.bentley.com/products/bridge_design___engineering/w/bridge_design_and_engineering__wiki/22482/straddle-bent----deck-offset-between-center-of-the-deck-and-center-of-the-bent-cap
