Different Column Materials and Types in LEAP Concrete
I would like to analyze a multi column pier with two column types within the substructure module of LEAP Steel. There are three original concrete columns and two retrofit columns. I would like to specify different end conditions and material properties for the retrofit columns, is that possible when opening LEAP concrete within LEAP Steel? It seems setting different conditions for each column is possible within the seperate LEAP concrete program, but when opened as the substructure module within LEAP Steel it is not possible anymore.
In this case, is there anyway to export the loadings from leap steel and import them into a standalone LEAP Concrete Substructure file?
