I am trying to extract footing design results and I noticed that it is getting struck/broken and closing out. When I uncheck design footing using P-delta effect it is producing results. I placed the LEAP file in the following link in addition to the screenshot of error. https://volkertcompany-my.sharepoint.com/:f:/g/personal/sai_gonuguntla_volkert_com/EoZLRGuXDu1Fv709KsjVu2IB-u-f-OVZ8EbQ8_59Z-s50w?e=ONo95SThank you
I tested this issue on OBD V10.10.20.34
LBC - 21.02.00.38 .
In the first trial i had the design footing using P-delta effect option being unchecked and the program did generate the footing results.
1) I unchecked the design footing using P-delta effect option .
2) I clicked on the Column Design status option.
3) Then clicked on the Footing Design Status option. The program did generate the footing results.
In the Second trial i had the design footing using P-delta effect option being CHECKED and the program did generate the footing results.
1) I CHECKED the design footing using P-delta effect option .
If you are using older version of LBC then please do upgrade it to the current release version.
For more information, on related topics please check the Bentley community's link.
https://communities.bentley.com/products/bridge_design___engineering/w/bridge_design_and_engineering__wiki/23796/p-delta-effect-in-footing-design
Vinay
