Hinges in LEAP Steel
I am building a curved steel bridge to model using a grillage analysis. I have located hinges according to plans and the hinge location dialog shows them at the correct locations. However, after I run the model the hinges are in a different location than defined. They are also at different location in the STAAD model created within LEAP Steel. Is there a reason the hinges would be relocated during analysis?
Parents Reply Children
